Guys,
I generally search for answers before posting. This is one such find but not answered.
This is actually a 10 year old thread, but the issue still continues..
You create a view in an idw file for a ipt file. Keep the Manage tab active. Click the view & hit update (Thunder bolt)
The view updates and the thunder bolt greys out. Good so far. Click out side the view for once and then click the view again to make it active. The update icon becomes avilable. Why?
Why should a file/view need update when its already up-to-date? It makes sense to have it when there is a real change in the part and the the view need update.
This is as designed behavior. Update in Drawing Manager behaves similar as "Rebuild All' in part environment - it forces view to recompute even if the model didn't change after last update. This is helpful when a view needs to be updated manually after a bug fix released or so.
Normally views on the active sheet should be updated automatically.
Ladislav
