Hi there,
In drg file, i have hidden few 2D drawing lines of some component, with 'select edge property'. I forgot the way to retrive the lines back.
simple one. can some one help me.
BR/ Xmer
Solved by Martin_Goodland. Go to Solution.
Hi
Right click in the view and select 'Show Hidden Edges'. The edges will be highlighted and you can select the ones you want to turn back on then right click and select 'Done', or you can right click and there is a show all option.
Regards
Martin
