Inventor Forum
idw detail view, default the view annotation on a leader
3 REPLIES 3
stephengibson76
864 Views, 3 Replies
when i create a detail view, whats the style setting to add a leader?  i would like the view label next to the circle or square to default to a leader attached to the circle / square, currently i RMB on the label, add leader then drag it to make the leader appear
thanks
Stephen Gibson
View stephen gibson's profile on LinkedIn
3 REPLIES 3
Cadmanto
in reply to: stephengibson76
Stephen,
What version are you running?
I know I have always RC'd on the label text and chosen leader as well.  I have looked in the styles, and have not found anything to make this the default.  I too, if there is an option, would like to know where that setting is.
I don't know about you, but I never leave the label text within the detail circle or square.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
stephengibson76
in reply to: Cadmanto
2014, i cant find the setting either
Stephen Gibson
Cadmanto
Stephen,
You know what that means.  If it ain't there, an idea needs to be created to get it there.  So here you are.
Feel free to cast your kudo vote for it. Smiley Wink
http://forums.autodesk.com/t5/Inventor-IdeaStation/Drawing-Detail-View-Leader/idi-p/4378239
Best Regards,
Scott McFadden
