Inventor General
Valued Contributor
floccipier
Message 1 of 4 (705 Views)
idw Template
705 Views, 3 Replies
05-16-2012 04:20 AM
Hi All,
I was trying to make new .idw (inventor) templates based on .dwg (autocad) templates. For some reason the type face Simplex is not showing correctly on screen and on print outs. I have checked on various machines and result was same.
is simplex not compatible??
Please advise.
Sajid Mahmood
mcgyvr
Message 2 of 4 (699 Views)
Re: idw Template
05-16-2012 05:15 AM in reply to: floccipier
Use Arial or other similar font.. Simplex worked great in the Autocad days of pen plotters,etc.. but does not work well with Inventor..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
sam_m
Message 3 of 4 (693 Views)
Re: idw Template
05-16-2012 05:56 AM in reply to: floccipier
Inventor and AutoCAD use different fonts - AutoCAD uses SHX (i think) and Inventor uses Window's native TTF fonts.  So, it's best to change over to a different font with Inventor.   Also, as a tip, it's probably best to start a brand new idw template and create it within Inventor instead of importing an old AutoCAD dwg border as it can often have a load of extra lines/points/rubbish/etc which will only be a greater overhead in cpu and file-size as you go on.
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Valued Contributor
floccipier
Message 4 of 4 (660 Views)
Re: idw Template
05-21-2012 11:37 PM in reply to: sam_m
Thanks alot for your help guys.
I need some more help regarding templates.
Sadly I have to convert drawings from idw to dwg quite alot and every time when i get drawing from inventor to autocad I have to fix the layers as per my autocad template (conventional layers that are turned on/off in certain layouts to show the certain details). What is better and easiest way to do this?
Any helping coments/links will be much appreciated.
Sajid Mahmood
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
