I have made a drawing template with a title block that has iProperties of “Sheet Number xx of xx”. Similar to what is described as on page 545 of Mastering Inventor 2012 By Curtis Waguespack. I can find the iProperties of the Sheet Number in the Model but I cannot find where to modify the input for the “of” field. Or where does The Format Text, Type Drawing Properties, Property, <Number of sheets>, field link to?
Yours truly C.A. Thaemar
Solved by jletcher. Go to Solution.
You type it in. It is on your keyboard you press the letteer O then press the letter F this gives you OF.
Or are you looking for the "Number of sheets" not the OF part? That is here..
The way I read your post you was looking for the word OF not the Text Parameter of the "Number of Sheets"
The title of the thread should have been where can I find the Number of Sheets Parameter
Not
Where is the of, of Sheet Number xx of xx.
See this is asking where OF is not Number of Sheets Parameter
