Inventor Forum
iProperties Question
12 REPLIES 12
Message 1 of 13
SteveFrey
426 Views, 12 Replies
In my .IDW I use the balloon to identify parts in the drawing by name by pointing to the item description in the iProperties.  I have several sub-assemblies (hinges) that consist of 20 or so parts and I want to be able to balloon this assembly by pointing to it like I do standard parts.  Is there a way that I can accomplish this without naming each description the same thing?  The hinge is something we purchase and do not modify it.  I still want my BOM and Parts List to reflect one hinge and by type (top or bottom).  Can anyone shed some light on this for me?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
12 REPLIES 12
Message 2 of 13
Lancasterm
in reply to: SteveFrey
If the hinge (assembly) is purchased, what about making the hinge just a part or a derived part in the assembly?  For us we don't want to manage purchased components as assemblies.   Another idea is to make the parts that form the hinge assembly as reference (BOM structure) parts.
Update:
Also what type of BOM are your using:  Structured or Parts Only?
Message 3 of 13
rhasell
in reply to: Lancasterm
I assume you have done the usual of Structured and Parts ony etc.
What I have done is create a custom property. This property is a bit of a ****, because It is used in so many of my fields.
It started from Engineering drawings, so my property is called "ENG" In hindsight, not the best, but everything is setup to use this field.
The balloons all refer to ENG
The Drawing title block refers to ENG
View names refer to ENG.
It find it much easier to rename the ENG field than to rename/use the description/part number/stock number.
If needed I also have an ENG2.
It might not solve your immediate problem, but it might help in the future?
Reg
2024.2
Please Accept as a solution / Kudos
Message 4 of 13
cbenner
I like Lancasterm's suggestion... make the hinges derived parts.  That way they show up in your parts list and BOM as a single item, and reflect what you are actually buying... a unit.  We do this a lot with valve assemblies that we buy pre-assembled, the unit has a single part number, and there is no need for us to show the components in our BOM... only the valve assembly itself.
Hope this helps.
Message 5 of 13
jddickson
Here is a link that might help you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Leader-Text-Question/m-p/4317172#M475547
I hope this helps.
Message 6 of 13
rhasell
Just a quick thought.
Have you tried setting the Hinge sub assembly as "Inseperable" in the BOM?
Reg
2024.2
Message 7 of 13
SteveFrey
in reply to: rhasell
No, but I will try it.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 8 of 13
SteveFrey
If I make it into a part then I can't use it in any pos reps, etc.  I still need it to move.  If I mark the parts of the assembly as Reference Parts will it still be identified when I balloon it?  I'll have to try it.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 9 of 13
SteveFrey
in reply to: cbenner
I will try it.  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 10 of 13
Try setting the BOM Structure to purchased for your hinge assembly.
Message 11 of 13
RobertaLaSesus
I do the same thing (balloning) to number components.  Usually it messes up and I end up just manually numbering to match the BOM.
R.
Message 12 of 13
rhasell
in reply to: RobertaLaSesus
I haven't tested positional reps when setting an assembly as inseparable, I will do so on Monday. At least you can reference the assembly as a single item in the BOM and balloons.
I would stay away from reference, because its, not and it will cause issues when detailing.
Reg
2024.2
Message 13 of 13
rhasell
Ok done. it works.
Hope it works for you.
I took two plates and put them together and created 2 positional reps. I set the BOM to Inseperable, and this is the result. (2 x Hinges, not 4 plates.)
Reg
2024.2
