Inventor General
Valued Contributor
Message 11 of 11 (53 Views)
Re: iParts properties not updating in idw
09-12-2012 11:16 PM in reply to: caza
if you're using vault, make sure you have the factory member file also checked out, otherwise regenerating it will not work as it is write protected. You won't get a message from inventor for that so you can regenerate all you want.
Something that can force inventor to see you modified the model, and therefor require regeneration of the files, is simply to edit a feature. (For instance edit a hole feature by re-typing one of the values.) Then you'll be sure to need an update of the member files.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
