Inventor Forum
iParts - modify at a later date
7 REPLIES 7
Message 1 of 8
249 Views, 7 Replies
Hello all,
I've now read through every post that has "iPart" in it and I think I can
draw these conclusions, and have the following questions.
1) Standard (as opposed to custom) iParts, once placed, can NOT be
modified - Ex. a cross-hole drilled. Please confirm.
Q: Separately, can R6 assembly features be applied to a set of
components in an assembly if one of these is a std. ipart?
2) If a Standard iPart needs a modification at a later date, and exists in
an assembly, the procedure is:
- Open the parent file of the ipart child.
- save copy as to the project folder.
- close the parent, open the new copy
- edit the table and make the desired child the default, close the
table.
- delete the table that makes it an ipart, save the file.
- return to the assembly and Replace Component, the ipart with the new
"non-ipart" component.
- make the modification to the new "non-ipart" component.
Please confirm this workflow.
Q: Are assembly constraints lost in the process?
Is there a better way to later modify a placed and constrained instance of a
standard iPart?
If there exists the possibility of alterations - Ex. add a set screw to a
gear, turn down a flange, add an oil groove, turn the id for a wiper, etc. -
should the iPart author sit back and ponder this as a driving force to make
his/her ipart a custom iPart in preference to a standard iPart?
7 REPLIES 7
Message 2 of 8
I have a project file set up with my library paths as the workgroup. If I
need to modify an ipart I switch to this project, and modify or add to my
iparts. About the only problem I have run into is if I add lines to the
table at the beginning - the current part loses its place in the table.
After I finish, I go back to the original project, and reopen the assembly.
Unless you changed geometry or deleted geometry in the ipart that you used
to constrain the ipart your constraints should stay intact.
Cory McConnell
BJ Pipeline Inspection
"Jack Brentner" wrote in message
news:A6EBBCCEE55F4877845DD986C16CEC14@in.WebX.maYIadrTaRb...
> Hello all,
> table.
a
> standard iPart?
etc. -
make
Message 3 of 8
Cory,
I'm trying to understand your response and interpret what you're trying to
tell me. It sounds like you're explaining the need to have an iPart project,
which I do, in order to edit iParts. But it appears you may have
misinterpreted my confusing babble - or I'm misreading your reply. I guess
what I was after was confirmation about the correct implementation of iParts
in the real-world inevitable situation of "Purchase & Alter". I'm mainly
concerned here about when a part must be altered, i.e. features added - to
just one instance. And how to author the iPart that makes alterations easier
for a designer down the road.
Another thing your response brings to mind that I'm not clear on, is the
addition of suppressible features to iPart parents that have already "been
fruitful" or already have offspring. IOW, if I do go back and add a feature
to the standard iPart parent that represents the alteration, and add a
column to suppress that feature in all but the part I am altering, would it
make all the existent children "flip out" or become unresolvable (especially
the one back in the current assembly I'm working on)? It would seem this
approach would lead to new children from the parent with additional features
that the "older children" do not possess at all. I guess it brings to mind a
question about the evolution of a standard ipart family - can standard ipart
families "evolve" in this way - gain features over time? I suppose many of
these things can be determined with a bit of experimentation.
Many Thanks,
Jack
-sorry replied directly earlier.
"Cory McConnell" wrote in message
news:6D35DAD4096BB56FF8CCB27D20ED4FFA@in.WebX.maYIadrTaRb...
assembly.
> Cory McConnell
> > Hello all,
can
in
> > table.
new
of
> a
> > standard iPart?
a
> etc. -
> make
Message 4 of 8
Clarification to point 2):
2) if a Standard iPart needs AN ADDITIONAL FEATURE or ALTERATION at a later
date.
> Hello all,
> table.
a
> standard iPart?
etc. -
make
Message 5 of 8
For purchase parts which I alter one instance of I do the following: I open
the ipart and comput the part I need to use. I save it with that size
active. I start a new part and derive in the ipart. Then I break the link
and modify away. As for editing iparts, I have never added to many
features - it is like you say, some experimentation may be necessary.
Cory McConnell
news:5CBE0EFAED8AA02DF728CA246A47BDB5@in.WebX.maYIadrTaRb...
later
> date.
> > Hello all,
can
in
> > table.
new
of
> a
> > standard iPart?
a
> etc. -
> make
Message 6 of 8
Can you not add features and then suppress them? So all the iparts except
one have the features suppressed.
Kathy Johnson
news:1356D6F2C21B7E68E4D52DB02CB2FFA1@in.WebX.maYIadrTaRb...
open
link
> Cory McConnell
> later
> > date.
> > > Hello all,
> can
exists
> in
> > > table.
> new
instance
> of
> > a
> > > standard iPart?
to
> a
> > etc. -
> > make
Message 7 of 8
Yes you can.
Cory McConnell
BJ pipeline Inspection
"KJohnson" wrote in message
news:CDE7A1B4E289A573E7434A8F7DB35EB4@in.WebX.maYIadrTaRb...
> Kathy Johnson
> open
> link
> > Cory McConnell
> > later
> > > date.
> > > > Hello all,
I
> > can
> exists
> > in
the
> > > > table.
the
> > new
> instance
> > of
> > > a
> > > > standard iPart?
> to
> > a
wiper,
> > > etc. -
to
> > > make
Message 8 of 8
That's pretty much how I do it as well.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
open
link
> Cory McConnell
> later
> > date.
> > > Hello all,
> can
exists
> in
> > > table.
> new
instance
> of
> > a
> > > standard iPart?
to
> a
> > etc. -
> > make
