I am having issues with Iparts and iLogic that hopefully someone can set me on the right path with incase what I am doing is not supposed to be done.
I have created a basic sheet metal chassis with some holes in it.
These hole positions are movable with parameters.
I can create an ipart with these positions in the table
I also have a custom iParameter which is a string, that is interpretted by an iLogic rule that can then show or supress these holes, thus making the chassis quite universal.
All works great, the holes move and suppress as expected.
Yet when I create the files for my iparts the rule doesn't get copied across so when it is saved or modified Inventor complains about the missing rule, this does't stop the file being saved but it concerns me that it is complaining
I can see why it complains, but why isn't the rule copied across?
As it isn't, is my approach wrong?
Is there a way around it?
Thanks in advance
Solved by mrattray. Go to Solution.
Hello Mike,
what am I trying to do that makes me think I need to use both?
To be honest I haven't played or thought about iLogic parts on their own, iParts I have. Having the table of parameters seemed the way to go. Then in order to go one step further to suppress holes according to a table value, iLogic was the answer. It all seemed to work ok so I hadn't bothered to look anywhere else, the only flaw was the annoying 'missing rules' warning, I had been getting much more series VB errors yesterday but I had managed to get rid of them.
The idea was that I would have one ipart that could generate numerous base chassis types, from one of these base chassis I would derive a part that I could add extra special holes to, as well as SilkScreen decals inorder to make a special variant. The only reason why I doing it that way was to get round the problem that you can't seem to apply silkscreening decals to assemblies.
iLogic seems to be able to do what I want, after a quick look, though with a slightly different workflow than I had envisaged with iParts, not that this a problem mind you.
So thank you for the information Mike, unless Im doing something else wrong in my above workflow I think that should have fixed my issue!
Many Thanks
As im fairly new to Inventor I think it is going to take some time/trial and error to get used to what it lets me do, even though it probably shouldn't!
I did consider supressing items with the iParts table but there were lots to suppress and the table was starting to get far too complicated.
