Inventor General
Valued Mentor
GSE_Dan_A
Message 1 of 7 (243 Views)
Accepted Solution
iParts and Hole Feature
243 Views, 6 Replies
03-26-2013 09:25 AM
I have created an iPart which uses the Hole Feature (counterbore hole).  The hole is not threaded.  Is there a way to put the Hole Feature into the iPart table so when a user enters specific values, he/she could type in or select a bolt size and the counter bore hole feature will use the correct dimensions for said bolt size (ie.  I would like the counterbore holes for an M6 Socket Head Cap Screw.  So instead of typing in the counterbore hole diameter, depth, and bolt diameter, etc... it would automatically enter the default values.)  Or is this something that must use iLogic?
If you need further information, please ask.  I am using Inventor Pro 2013.  I can post an example of the part if needed.
GSE Consultants Inc.
Windsor, ON. Canada
*Expert Elite*
cbenner
Message 2 of 7 (236 Views)
Re: iParts and Hole Feature
03-26-2013 09:44 AM in reply to: GSE_Dan_A
I don't think there is any way to have an ipart prompt for user input.. This sounds like ilogic.  What else about the part can change?  Is it a basic shape and size, and only the hole size changes?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
*Expert Elite*
Curtis_Waguespack
Message 3 of 7 (233 Views)
03-26-2013 09:47 AM in reply to: GSE_Dan_A
Hi GSE_Dan_A,
I think we can do this by adding an If/Then in Excel to the iPart table, I'll work up a quick example, but it might be a bit before I get back to it.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Curtis_Waguespack
Message 4 of 7 (215 Views)
03-26-2013 11:00 AM in reply to: Curtis_Waguespack
Hi GSE_Dan_A,
When I had a look at this it dawned on me that just adding a User Parameter called HoleSize or something similar and then making that parameter a key might be all that is needed.
Attached is a simple example, with fictional hole data. Does this do what you need?
I hope this helps.
Curtis
Valued Mentor
GSE_Dan_A
Message 5 of 7 (208 Views)
03-26-2013 11:21 AM in reply to: Curtis_Waguespack
Thank you both for your responses.
Curis - I think your example will work well! I will give it a go and report back.
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 6 of 7 (178 Views)
03-27-2013 07:57 AM in reply to: Curtis_Waguespack
I may go in a different direction with the Check Fixture.  I was thinking more along the lines of a Form.
User opens Generic Check Fixture Part.
Opens up custom Form.
Enters relevant information.
Part is then created.
Now my question is if I have a Field set-up for Socket Head Cap Screw Size and a drop-down is available to select SHCS size (metric or imperial), how can I get the counterbore dimensions to be linked with the Form?  For example the user selects M8, I would like the counterbore holes to reflect the required dimensions (diameter, depth, etc...)
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 7 of 7 (170 Views)
03-27-2013 08:25 AM in reply to: GSE_Dan_A
Here is my example I am working on.  I have the Form included.  What I would like to have is Hole5 be a drop down within my Form so when the user selects a SHCS size, the counterbore will update with the correct dimensions.
Windsor, ON. Canada
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
