Inventor General
*Expert Elite*
Cadmanto
Message 1 of 6 (253 Views)
iParts Generating Folders
253 Views, 5 Replies
06-07-2012 07:03 AM
When we create iparts and generate the files from the mother ipart, Inventor creates an additional folder to place the iparts into.  Is there a setting somewhere to force Inventor to place these generated files into a user defined location?
Or is this just something we have to live with and do we have to manually move the files after generating them.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
Curtis_Waguespack
Message 2 of 6 (245 Views)
Re: iParts Generating Folders
06-07-2012 07:15 AM in reply to: Cadmanto
Hi Cadmanto,
For the most part you have to live with it. But it would be nice to have the abilty to define the file store location for each iPart factory.
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
If by chance your iPart factories can all be placed in a library folder, then you can set up Inventor to write the files to a single directory. Attached is a slide I had on hand that covers the set up for this.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Cadmanto
Message 3 of 6 (227 Views)
06-07-2012 07:44 AM in reply to: Curtis_Waguespack
Hi Curtis,
Thanks for the link.  Not sure if dumping all of our generated iparts into one folder will work for us, but I have put it out there for discussion here.  I also placed an enhancement request into the link you provided as well.
Thanks for your help again.
Best Regards,
Scott McFadden
Lance_White
Message 4 of 6 (202 Views)
06-07-2012 11:27 AM in reply to: Cadmanto
Well it would be nice to change the location of the folder. I'm wondering though why do you want to move the files?
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
*Expert Elite*
Cadmanto
Message 5 of 6 (188 Views)
06-07-2012 01:25 PM in reply to: Lance_White
Only so the are in one central location not only on the local drive, but in the vault.
Best Regards,
Scott McFadden
Lance_White
Message 6 of 6 (171 Views)
06-08-2012 05:31 AM in reply to: Cadmanto
If you generate all the files when you check in the master iAssembly it will check in all of the individual files also. What we do is put the master iasmbly files in a seperate folder and give them descriptive names with the individual versions getting a number. When they are created we leave them in the subfolder and check in the master. The annotation files are created and saved in our normal folder structre.
Yes that seperates the iam and idw/dwg file but it also makes it easier to update the iassembly when needed.
Lance W.
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
