I have an IPart with about 100 instances in it that is sheet metal. I created a user parameter for the gauge of the sheet metal relating to the thickness and that works fine in the ipart. My dilema is how to get the gauge to show up in my drawing in the general table. Pretty much I woud like the table to list part number, material and then have a column for the gauge of the steel related to the thickness in the Ipart table. I am using Inventor 2011 if that makes a difference.
Joey
I am not sure what you mean is it for a template. It will be a drawing that uses the table to specify dimensions on a single drawing for the multiple instances of an Ipart.
Joey
