Inventor Forum
iPart members & body appearances
4 REPLIES 4
505 Views, 4 Replies
Am I missing something or is there no easy way to control the appearance of each body on a per member basis in a multi-body ipart family?
4 REPLIES 4
CCarreiras
Hi!
I only know the way to change material or appearence, but for whole the bodies.
You find a way to do that for each solid?ie each solid with different color?!
CCarreiras
in reply to: CCarreiras
Yes, each solid with a different colour depending on which family member is active is my goal.
I was thinking maybe iLogic to set which view to use for each member but I've got no idea on how to set that up, all I've found so far is some iLogic code to set an active view, but nothing that is helping me link it back to the different members of the ipart family.
AKloos
I'am having the same problem/question.
Can Autodesk give an answer on that question, please.
Thanks in advance.
AKloos
Inventor Professional 2014
blair
in reply to: AKloos
Short of changing the extrusion color properties, is short no. By definition, a multi-body solid is a single material. The only time you have control of diferent material is when you "Push" the body "pieces" into individual parts "IPT's".
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
