Inventor General
Distinguished Contributor
shastu
Message 11 of 14 (31 Views)
Re:
11-21-2002 05:17 AM in reply to: shastu
Drew, not sure I follow you. The filename and the part number would be the same, although you can't see the filename(in the browser) when using ranges.
*Keller, Kent
Message 12 of 14 (31 Views)
Re:
11-21-2002 05:20 AM in reply to: shastu
Maybe I am missing it all, but if you are using custom iParts and you just want the
filename to show the length can't you just have the users enter the filename including the
length when they save the custom iParts? Have a feeling I am missing it ..8^)
Kent
Member of the Autodesk Discussion Forum Moderator Program
"shastu" wrote in message news:f126216.8@WebX.maYIadrTaRb...
> Sean, I am talking about the BOM, but I didn't want to have to add the length column to
parts list. I wanted to be able to just include it in the description column if a length
value was used. Steel shapes are the only thing that are going to be like this. In MDT6 I
made this happen with the following equation in the BOM Properites Dialog box: = (DIM, 0),DESCR-STANDARD,DESCR-STANDARD " X " DIM)> Basically it means if DIM (which is the
length) = 0 then display the DESCR-STANDARD, else display the DESCR-STANDARD X DIM.
shastu
Message 13 of 14 (31 Views)
Re:
11-21-2002 05:33 AM in reply to: shastu
Not sure why filename keeps coming up. When I add a parts list I have four columns showing. The Bubble #, Quantity, Part Number, and the Description. What I am wanting to do is the same thing I did in MDT6. If there is a length I want it to show attached to the end of the Description in the Description column.
*Dotson, Sean
Message 14 of 14 (31 Views)
Re:
11-21-2002 05:46 AM in reply to: shastu
OK, I think I'm beginning to see what you want to
do..
still no...
You want to reference the length parameter but that
parameter is not defined until the user creates the part and gives it a filename
and saves it.  So in the Excel sheet the length is not set till after the
part # is created (which can be defined in the table but it will always be the
same for a given key e.g. a given structural shape.)
It may be possible to concatenate this length (if
it's a custom parameter) with the description but I'd have to give it some
thought.  My get feeling so there is not a way.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
Not
column.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
