Inventor Forum
iPart Issue
1 REPLY 1
xmer
279 Views, 1 Reply
iPart Issue
Hi all,
I'll be really thanksful, if somebody can give some direct solution.
Here we go.. I have an iPart with 10 Variation. Actually it is an assembly. but for the purpose of convinience I made it into iPart. I know the physical weight of all 10 variation.
When i create this iPart, the variation weight don't match with actual. so I want to incorporate the already determined weight for each variation. therefore I can get the same, when i use it in BOM.
iPart excel, is not giving option to add mass property.  It can be done by changing density. but I want to keep the same density.
Is there any other possibilities..???
Thanks in advance..
1 REPLY 1
cwhetten
in reply to: xmer
The thread linked below deals with the same question.  You may find some answers there.
http://forums.autodesk.com/t5/Autodesk-Inventor/Adding-Mass-Overides-to-Iparts/m-p/3271247#M421537
