Can anybody help????
This might sound like a silly question!!!!!
I am currently using a "addin" to monitor the "Save" button press on Anventor. It runs every time I press the "Save" button regarless on the type of document I have open (ipt, idw, iam).
Can I use iLogic in the same way so I can remove the "addin"?
All I need it to do (For test only!!!) is to display a message box every time the user presses the "Save" button regardless of the document type.
so therfore, if I close inventor and reopen a part, drawing, or assembly, it will always run.
Many thanks in advance!!!!
Darren
Hi Darren,
you will find more answers posting this here:
http://forums.autodesk.com/t5/Inventor-Customization/bd-p/120
Good Luck!
Admaiora
This will only happen if a change has been made I have no idea way because the trigger is set to go when saved but seem to only work if something changed.
Just put this rule in all your templates and set event trigger..
Make a rule with this
MessageBox.Show("I WAS SAVED", "THANK YOU")
You can change the I WAS SAVED and the THANK YOU
After making the rule go to event triggers and put the rule in after save document..
Yes you are correct thanks for that... I did not think that would work...
Like Mike said change to this instead...
