Inventor General
Active Contributor
LewisLusby
Message 1 of 2 (178 Views)
iLogic to override density
178 Views, 1 Replies
01-14-2013 04:27 PM
Hi all.
Bit of a tricky one (for me anyway!). I'm driving an Inventor GA using iLogic, within this GA are various guard sub-assemblies..........(See example attached). I designed it so that if the material for the sub assemblies is changed then the sheet thickness is also changed (eg, if alu = 3mm sht, mld stl = 2mm). Look at the attached, the grey parts are, in reality, meshed. However i do not want to create the meshed profiles so can i override the density (x0.7) using iLogic. I could override the mass by adding (0.7 x mass) BUT this does not update if the geometry changes (also driven by the GA.
I hope this makes SOME sense,
Lewis
Active Contributor
LewisLusby
Message 2 of 2 (148 Views)
Re: iLogic to override density
01-20-2013 04:47 PM in reply to: LewisLusby
Anyone???:manfrustrated:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
