Inventor General
Active Contributor
CadlineSupport
Message 1 of 3 (472 Views)
Accepted Solution
iLogic to change the view representation in a part file
472 Views, 2 Replies
04-16-2012 09:14 AM
There is an existing thread on this forum showing how to change the view rep in an assembly (using oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Red").activate) - Thank you to Curtis Waguespack - however I am trying to achieve the same with iLogic in a part file (multi-solid). Is this possible please?
Many thanks
Product Support
Message 2 of 3 (464 Views)
Re: iLogic to change the view representation in a part file
04-16-2012 09:58 AM in reply to: CadlineSupport
Following iLogic rule activates "View1" and should work both in a part or in an assembly.
Keep in mind that viewreps capture the part and body appearance in a multi-body part but not the face or feature appearance.
Dim odoc As Document
Dim ocompdef As ComponentDefinition
odoc = ThisApplication.ActiveDocument
ocompdef = odoc.ComponentDefinition
Try
ocompdef.RepresentationsManager.DesignViewRepresentations.Item("View1").Activate
Catch
MessageBox.Show("This viewrep does not exist", "Error")
End Try
 Bob
Active Contributor
CadlineSupport
Message 3 of 3 (449 Views)
04-16-2012 12:59 PM in reply to: CadlineSupport
Superb! works perfectly thank you very much for the quick response
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
