Inventor General
Valued Contributor
linuskotte
Message 1 of 3 (142 Views)
iLogic syntax for searching in excel and update the iproperties
142 Views, 2 Replies
12-17-2013 08:39 PM
I want a illogic rule syntax for following process:
I have one excel sheet it consists around 5 sheets for Plate, Flats, Rounds, etc.,
When iam run the rule then it will ask and do the following:
  1. Ask the thickness value.
  2. It will search thickness value in “D:\LINUS KOTTE\stock numbers.xlsx” in sheet 1
  3. If thickness value found then fill the stock number in iproperty(project tab-stock number)
Here iam using different rules for plate, flat, round, etc.,
Thanks in Advance.
Thanks & Regards,
LINUS KOTTE
Employee
Yijiang.Cai
Message 2 of 3 (132 Views)
Re: iLogic syntax for searching in excel and update the iproperties
12-17-2013 09:27 PM in reply to: linuskotte
Please see the iLogic rule below, and this rule will get the vaule of stock number in excel when Thickness =1, then the value of stock number will be filled in the stock number in iProperty within part. And you could modify the 1 to other value.
i = GoExcel.FindRow("D:\LINUS KOTTE\stock numbers.xlsx", "Sheet1", "Thickness", "=", 1)
iProperties.Value("Project", "Stock Number") = GoExcel.CurrentRowValue("Stock Number")
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Valued Contributor
linuskotte
Message 3 of 3 (115 Views)
12-18-2013 02:31 AM in reply to: Yijiang.Cai
It showing error message how to solve this
I copied into ilogic editor and run then it shows this message
i = GoExcel.FindRow("D:\Book1.xlsx", "PLATE",  "Thickness", "=", 1)
in showing 3 sheets also same data
Thanks & Regards
LINUS KOTTE
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
