Inventor Forum
iLogic syntax for searching in excel and update the iproperties
2 REPLIES 2
linuskotte
563 Views, 2 Replies
I want a illogic rule syntax for following process:
I have one excel sheet it consists around 5 sheets for Plate, Flats, Rounds, etc.,
When iam run the rule then it will ask and do the following:
  1. Ask the thickness value.
  2. It will search thickness value in “D:\LINUS KOTTE\stock numbers.xlsx” in sheet 1
  3. If thickness value found then fill the stock number in iproperty(project tab-stock number)
Here iam using different rules for plate, flat, round, etc.,
Thanks in Advance.
Thanks & Regards,
LINUS KOTTE
2 REPLIES 2
Yijiang.Cai
in reply to: linuskotte
Please see the iLogic rule below, and this rule will get the vaule of stock number in excel when Thickness =1, then the value of stock number will be filled in the stock number in iProperty within part. And you could modify the 1 to other value.
i = GoExcel.FindRow("D:\LINUS KOTTE\stock numbers.xlsx", "Sheet1", "Thickness", "=", 1)
iProperties.Value("Project", "Stock Number") = GoExcel.CurrentRowValue("Stock Number")
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
linuskotte
in reply to: Yijiang.Cai
It showing error message how to solve this
I copied into ilogic editor and run then it shows this message
i = GoExcel.FindRow("D:\Book1.xlsx", "PLATE",  "Thickness", "=", 1)
in showing 3 sheets also same data
Thanks & Regards
LINUS KOTTE
