Hello
Hope someone can help me with this iLogic rule.
I am not good with iLogic but I have this rule that gives me length and width of a sheetmetal part in mm and with , (comma). The rule works but the file will always accept saving regardless if there has been changes or not. I want the rule to only accept save IF there has been changes on SM_Length (=<FLAT PATTERN LENGTH> cm) and SM_Width (=<FLAT PATTERN WIDTH> cm) or Thickness.
Is this possible?
sLength = iProperties.Value("Custom", "SM_Length")
sWidth = iProperties.Value("Custom", "SM_Width")
sThickness = iProperties.Value("Custom", "Thickness")
sLength = sLength * 10
sLength = Replace(sLength,".",",")
sLength = Replace(sLength," mm","")
sWidth = sWidth * 10
sWidth = Replace(sWidth,".",",")
sWidth = Replace(sWidth," mm","")
sThickness = Replace(sThickness,".",",")
sThickness = Replace(sThickness," mm","")
sThickness = Round(CDbl(sThickness),1)
iProperties.Value("Custom", "Length") = CStr(sLength)
iProperties.Value("Custom", "Width") = CStr(sWidth)
iProperties.Value("Custom", "Thickness") = CStr(sThickness)
Best Regards
TEG
So you're changing the values of your iproperties to get the part to update, correct?
I would create another set of iproperties for SM_Length / SM_Thickness / SM_Width
Let's call them
SM_Length_Old SM_Width_Old SM_Thickness_Old
Then I would change the code so that it would update those values at the end of the code, but look to make sure that they aren't equal at the beginning.
Dim SM_Length, SM_Width, Thickness, SM_Length_Old, SM_Width_Old, Thickness_Old As Double SM_Length = iProperties.Value("Custom", "SM_Length") SM_Width = iProperties.Value("Custom", "SM_Width") Thickness = iProperties.Value("Custom", "Thickness") SM_Length_Old = iProperties.Value("Custom", "SM_Length_Old") SM_Width_Old = iProperties.Value("Custom", "SM_Width_Old") Thickness_Old = iProperties.Value("Custom", "Thickness_Old") If SM_Length_Old <> SM_Length Or SM_Width_Old <> SM_Width Or Thickness_Old <> Thickness Then sLength = SM_Length sWidth = SM_Width sThickness = Thickness sLength = sLength * 10 sLength = Replace(sLength,".",",") sLength = Replace(sLength," mm","") sWidth = sWidth * 10 sWidth = Replace(sWidth,".",",") sWidth = Replace(sWidth," mm","") sThickness = Replace(sThickness,".",",") sThickness = Replace(sThickness," mm","") sThickness = Round(CDbl(sThickness),1) iProperties.Value("Custom", "Length") = CStr(sLength) iProperties.Value("Custom", "Width") = CStr(sWidth) iProperties.Value("Custom", "Thickness") = CStr(sThickness) SM_Length_Old = SM_Length SM_Width_Old = SM_Width Thickness = Thickness_Old End If
*Note, I ended up making all of those declarations up there for your iprops into new vars, because I of the code window size restrictions. It ended up looking pretty cramped (unreadable) in the raw way, and all of those Or statements would have been silly. Also, I declared those are Doubles, as I am assuming that you're using a Number Type iProperty.
I hope that this helps.
Thank you very much for your answer
I have tried it but my iprops are text and perhaps that is why I get these errors?
Do you have a tip for this?
Best regards
TEG
Just to be sure. You never confirmed your work flow. Are you updating the iProperties, and then hoping to update the User Parameters from those values, or the other way around?
If it's iProperties -> Parameters then you could just use this :
If iProperties.Value("Custom", "SM_Length") <> sLength Or _ iProperties.Value("Custom", "SM_Width") <> sWidth Or _ iProperties.Value("Custom", "Thickness") <> sThickness Then sLength = iProperties.Value("Custom", "SM_Length") sWidth = iProperties.Value("Custom", "SM_Width") sThickness = iProperties.Value("Custom", "Thickness") sLength = sLength * 10 sLength = Replace(sLength,".",",") sLength = Replace(sLength," mm","") sWidth = sWidth * 10 sWidth = Replace(sWidth,".",",") sWidth = Replace(sWidth," mm","") sThickness = Replace(sThickness,".",",") sThickness = Replace(sThickness," mm","") sThickness = Round(CDbl(sThickness),1) iProperties.Value("Custom", "Length") = CStr(sLength) iProperties.Value("Custom", "Width") = CStr(sWidth) iProperties.Value("Custom", "Thickness") = CStr(sThickness) End If
I don't know why I didn't see that the first time around...
I tested that on your part (after turning d5, d6 into sLength and sWidth respectively, and creating a User Parameters called sThickness), and everything seemed to work fine. The body of the rule will not run unless you change those particular iproperty values, however, it should be kept in mind that you will dirty the part (make it so that it prompts you to save) if you change anything in the iProperties at all even if they don't involve those parameters. A change is a change!
