Inventor Forum
iLogic range between two numbers; not working
2 REPLIES 2
RemcoVerschuren
2255 Views, 2 Replies
I would like to use the if else parameter in iLogic to set up a range, but I'm not getting it right.
Maybe you got any idea?
What should happen:
if the variable 'breedte' is:
-       0 up to 3800; thats OK
- 3800 up to 4000; thats not OK, use 3800 instead
- 4000 and up; thats OK
Therefore I wrote this script, but when I enter a number between 3800 and 4000 (like 3900), the MessageBox appears (thats good), but the size of my solid results in 3900, instead of 3800.
breedte = InputBox("What is the breedte?", "Hoofdmaten", "")
	Parameter("skelet.ipt.breedte")=breedte
If breedte <= 3800 Then
  breedte = breedte
Else If breedte >= 4000 Then
  breedte = breedte
Else If (breedte >= 3801) AndAlso (breedte <= 4000) Then
  breedte = 3800
  MessageBox.Show("This breedte is not possible." & hoogte & vbCr & "The value of 3800 will be used instead.", "Problem message", MessageBoxButtons.OKCancel, MessageBoxIcon.Asterisk)
Tags (2)
2 REPLIES 2
mrattray
in reply to: RemcoVerschuren
Well I would write this as :
If breedte > 3800 and breedte < 4000 Then
  breedte = 3800
I think the issue is from setting the value in your skeleton part before you did your error check.
Mike (not Matt) Rattray
RemcoVerschuren
in reply to: mrattray
Great!
Moving the Parameter rule is solving the problem.
Thanks mrattray Smiley Wink
