Inventor Forum
iLogic help with changing iproperties in all open files and assemblies
1 REPLY 1
ageezee
406 Views, 1 Reply
I have an assembly with sub assemblies and subassemblies below that.  I use an .ipt with a bunch of custom user paramaters to drive all sorts of things.  I'm trying to right an ilogic rule to place in the upper assembly that will pull a user paramater and map it to a custom iproperty of all the files in the assembly, including all lower assemblies and ipt's.
I found some code on here that works to change the assemblies but not any of the sub assemblies or ipts below.
' set a reference to the assembly component definintion.' This assumes an assembly document is open.Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrencesDim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components'(in case a virtual component trips things up)If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'set part number for each componentiProperties.Value(oOccurrence.Name, "Custom", "TRUCK") = Parameter("MEDSKETCH:1", "TRUCK") & ""
Else
Next
I'm fairly new to ilogic and VBA and would appreciate any help!
Thanks.
Anthony
1 REPLY 1
cwhetten
in reply to: ageezee
Have you considered using Design Assistant to help you change the value of an iProperty (or many) all at once?
-cwhetten
Please click "Accept as Solution" if this response answers your question.
