Inventor General
New Member
ageezee
Message 1 of 2 (214 Views)
iLogic help with changing iproperties in all open files and assemblies
214 Views, 1 Replies
01-15-2013 11:33 AM
I have an assembly with sub assemblies and subassemblies below that.  I use an .ipt with a bunch of custom user paramaters to drive all sorts of things.  I'm trying to right an ilogic rule to place in the upper assembly that will pull a user paramater and map it to a custom iproperty of all the files in the assembly, including all lower assemblies and ipt's.
I found some code on here that works to change the assemblies but not any of the sub assemblies or ipts below.
' set a reference to the assembly component definintion.' This assumes an assembly document is open.Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrencesDim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components'(in case a virtual component trips things up)If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'set part number for each componentiProperties.Value(oOccurrence.Name, "Custom", "TRUCK") = Parameter("MEDSKETCH:1", "TRUCK") & ""
Else
End If
Next
I'm fairly new to ilogic and VBA and would appreciate any help!
Thanks.
Anthony
cwhetten
Message 2 of 2 (193 Views)
Re: iLogic help with changing iproperties in all open files and assemblies
01-15-2013 03:06 PM in reply to: ageezee
Have you considered using Design Assistant to help you change the value of an iProperty (or many) all at once?
-cwhetten
Please click "Accept as Solution" if this response answers your question.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
