Inventor Forum
iLogic for View Representation of Part File (in Assy)
2 REPLIES 2
CadlineSupport
1717 Views, 2 Replies
Hi
I have received a great solution from Bobvdd allowing ilogic control of the view rep in a part file (not an assembly file). The code below works brilliantly when the part file is the active document. However when the part is placed in an assembly and the ilogic is run with the assembly active, the code produces no result. Is anyone able to advise on how to modify the top 6 lines of code? Many thanks for your help.
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim ocompdef As ComponentDefinition
ocompdef = odoc.ComponentDefinition
'Then apply specified View Representation
If Colour = "Red" Then
ocompdef.RepresentationsManager.DesignViewRepresentations.Item("Red").Activate
2 REPLIES 2
Hi CadlineSupport,
Here is a basic "template" I've used for working with parts in assemblies. You can give it a go, I didn't have a chance to try it though.
Here is another approach that might work:
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-set-Design-View-Representation-by-material/m-...
I hope this helps.
Curtis
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
'kAssemblyDocumentObject = 12291
If openDoc.DocumentType = 12291 Then
	'Iterate though the part files in the assembly
	For Each docFile In openDoc.AllReferencedDocuments
		'kPartDocumentObject = 12290
		If docFile.DocumentType = 12290 Then
		'-------- your code here --------
	Next
	Else
	MessageBox.Show("This file is not an Assembly.", "iLogic")
Thank you for the quick response Curtis, very much appreciated. I have tried the code you suggest in the assembly (with my own simple code added) and it gives me the 'Parameter is incorrect' error when running. Am I doing something obvious wrong? Thank you
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Define the open documentDim openDoc As Document
           oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Red").Activate
   Next
    Else
