Inventor Forum
iLogic for Export the iproperties
1 REPLY 1
linuskotte
810 Views, 1 Reply
I created one iLogic rule for exporting iproperties into excel sheet like below.
GoExcel.Open("D:\Properties\iPROPERTIES.xlsx")
GoExcel.CellValue("A3") = iProperties.Value("Summary", "Title")
GoExcel.CellValue("B3") = iProperties.Value("Summary", "Author")
MessageBox.Show("iProperties successfully copied!")
This is working for only one file but I want export all the inventor files properties into excel sheet in a current folder.
And next part properties sholud be in next row and third part properties shold be in third row Like.
Part2:
GoExcel.CellValue("A4") = iProperties.Value("Summary", "Title")
GoExcel.CellValue("B4") = iProperties.Value("Summary", "Author")
Part3:
GoExcel.CellValue("A5") = iProperties.Value("Summary", "Title")
GoExcel.CellValue("B5") = iProperties.Value("Summary", "Author")
Thanks in Advance
Thanks and Regards,
LINUS KOTTE
1 REPLY 1
naresh_kalyan
in reply to: linuskotte
Linus,
I have not that much exposure on iLogic. But, I would suggest you to do the same using VBA. It does much more options
Dim ofile As Scripting.file
Dim flsysobj As FileSystemObject
Dim sfolder As Scripting.Folder
Set flsysobj = New FileSystemObject
Set sfolder = flsysobj.GetFolder(opath) ' oPath Need to be defined by you
For Each ofile In sfolder.Files
   If Right(ofile.name, 4) = ".ipt" Or ".iam" Or ".idw" Then    ' need to be decided by you as per the files you are working with...
   Set odoc = ThisApplication.Documents.Open(ofile, True)
   ' wrtie the code which you have written in iLogic----------------------
     odoc.Update
    odoc.Save
   odoc.Close
Next
Msgbox "Completed"
Have a good Day....
