Inventor Forum
iLogic code to embed externally ran rule to ipt.
1 REPLY 1
Fleagle8t
431 Views, 1 Reply
Hi Folks,
I have put together some ilogic code which is embedded within a part template, this auto populates the iproperties with the profiles length,width and thickness, and also automatically updates when any changes are made to the said profile When I hit save.
This works a treat when creating new parts, the problem arises when re-using old parts from previous jobs (Which is a regular occurrence),prior to when the code was created.
  So I have to run the code as an external rule, but this has caught me,and a few other people out, as we have forgotten to run the rule after making a change to the part so the iproperties aren't automatically updated.
 My question is, is there a snippet of code that I could add to my code, which embeds the the externally ran rule to the Ipt?
I hope this makes sense???
1 REPLY 1
pcrawley
in reply to: Fleagle8t
You could run "Code Injector".  You can batch select all your old files and add your rule to them. Easy.
I have to say that Code Injector is the greatest iLogic-related tool ever.  Being able to push code into parts that previously didn't have code - or modify code on parts - or run code to change models... It's just awesome.
http://beinginventive.typepad.com/being-inventive/2012/02/injecting-ilogic-code-and-ilogic-event-tri...
Peter
