Inventor General
Distinguished Contributor
Breeze104
Message 1 of 17 (249 Views)
iLogic code not functioning correctly
249 Views, 16 Replies
02-08-2012 01:35 PM
The problem is that for some reason the bolts constraints are not suppressing.  It is simple on/off code but for some reason I am still getting constraint and component errors.
Had to add " " to get code to post...I don't actually have them in my code.
Here is the code:
"If HopperType = "10TADL" Or HopperType = "12BH" Or HopperType = "12TAD" Then
Component.IsActive("Component Pattern 1:1") = True
Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:1") = True
Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:2") = True
Component.IsActive("Hex Nut - Inch 5/16 - 18:1") = True
Component.IsActive("Hex Nut - Inch 5/16 - 18:2") = True
Constraint.IsActive("Insert:1") = True
Constraint.IsActive("Mate:80") = True
Constraint.IsActive("Mate:78") = True
ElseIf HopperType <> "10TADL" Or HopperType <> "12BH" Or HopperType <> "12TAD" Then
Component.IsActive("Component Pattern 1:1") = False
Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:1") = False
Component.IsActive("Hex Bolt - Inch 5/16-18 UNC - 1:2") = False
Component.IsActive("Hex Nut - Inch 5/16 - 18:1") = False
Component.IsActive("Hex Nut - Inch 5/16 - 18:2") = False
Constraint.IsActive("Insert:1") = False
Constraint.IsActive("Mate:80") = False
Constraint.IsActive("Mate:78") = False
End If"
Valued Mentor
Ktelang
Message 2 of 17 (242 Views)
Re: iLogic code not functioning correctly
02-08-2012 02:13 PM in reply to: Breeze104
As you are getting your bolts and nuts suppressed
I assume you have a custom level of representation
Please find the attached simulated condition the suppression condition is something
different : open model Bolted and unsuppress the connections
I have modeled 1 bolted connection and other place from content center at the same location
And then run the rules
Else please share the sample file
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Distinguished Mentor
swordmaster
Message 3 of 17 (233 Views)
02-08-2012 02:50 PM in reply to: Breeze104
If you are simply trying to suppress your hardware there is no need to suppress the constraints
try "commenting out" those lines and run the rules again
Similarly there is no need to suppress each instance of your pattern
Inventor 2010 Certified Professional
Breeze104
Message 4 of 17 (222 Views)
02-09-2012 04:32 AM in reply to: swordmaster
That is the problem I originally did just suppress the component pattern, but it still thru constraint errors eventhough they should have been shut off in all hopper types except those three listed.
Breeze104
Message 5 of 17 (218 Views)
02-09-2012 05:23 AM in reply to: Breeze104
Even coding it like this...the Component Pattern 1:1 is still active and giving error in Design Doctor.
If HopperType = "10TADL" Then
ElseIf HopperType = "12BH" Then
ElseIf HopperType = "12TAD" Then
Else
End If
Breeze104
Message 6 of 17 (214 Views)
02-09-2012 05:49 AM in reply to: Breeze104
I wanted to give a quick thanks to ya'all for your help so far...
Eventhough it has solved the issue, I was able to go though all the other rules and really thin them down....THANKS
Breeze104
Message 7 of 17 (210 Views)
02-09-2012 06:03 AM in reply to: Breeze104
After using the form I created and switching hopper types I am finding out that the other hopper types that are suppsed to have the nuts and bolts in them aren't correct either.
What is happening is that the nuts and bolts are active but the constraints to put them in place are not activating, so they end up where ever on the end plate of the hopper.
See Pic : http://screencast.com/t/c9SHhdJL
Breeze104
Message 8 of 17 (204 Views)
02-09-2012 06:31 AM in reply to: Breeze104
Seems my typing skills need some help...
Was suppsed to read "Eventhough it hasn't solved the issue......"
Sorry about that
Breeze104
Message 9 of 17 (202 Views)
02-09-2012 06:46 AM in reply to: Breeze104
One other thing I have noticed looking over things.....is that if I right click on Component  Patteren 1:1 is shows a check mark by "Suppressed", but for some reason it is throwing the "Component Pattern failure" error in Design Doctor.
swordmaster
Message 10 of 17 (197 Views)
02-09-2012 07:20 AM in reply to: Breeze104
Ok,
I made a small test to show how this pattern suppression works.
This code suppresses  the pattern named "my_pattern" and all of the instances of that pattern.
Based on the value of the parameter "my_configuration"
It does not to "touch" the constraints........these are still needed
trigger
= iTrigger0
if
my_configuration = 0 then
Component.IsActive
("my_pattern") = False
else
Component.IsActive
("my_pattern") = True
end if
iLogicVb.UpdateWhenDone
= True
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
