Inventor General
New Member
Misael_Ramalho
Message 1 of 4 (1,141 Views)
iLogic - Sheet Metal (Flat Pattern)
1141 Views, 3 Replies
04-09-2012 10:45 AM
Hello to all,
I created the iLogic Rule below for Sheet Metal template:
InventorVb.DocumentUpdate()
mass = iProperties.Mass
If (mass > 0) then
  Parameter.Value("LARGURA") = SheetMetal.FlatExtentsWidth
  Parameter.Value("COMPRIMENTO") = SheetMetal.FlatExtentsLength
  Parameter.Value("AREA") = SheetMetal.FlatExtentsArea
Else
  Parameter.Value("LARGURA") = 0
  Parameter.Value("COMPRIMENTO") = 0
  Parameter.Value("AREA") = 0
End If
iLogicVb.UpdateWhenDone = True
When creating a new individual files, everything works perfectly. But when creating a new Sheet Metal file in Assembly environment, the following message appears:
After of click "OK" appears Inventor Fatal Error and close the software.
Can anyone help me?
Curtis_Waguespack
Message 2 of 4 (1,140 Views)
Re: iLogic - Sheet Metal (Flat Pattern)
04-09-2012 10:51 AM in reply to: Misael_Ramalho
Hi M_Ramalho,
I think the error is occuring because the rule is looking for parameters that do not exist until your sheet metal part has a flat pattern present. You can add a conditional statement to check for an existing flatpattern before running the rule.
I hope this helps.
Curtis
a quick example:
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
'ensure this part has a flat pattern
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oDoc.ComponentDefinition
If oSMDef.FlatPattern Is Nothing Then
'tell the user there is no flat pattern
MessageBox.Show("This file has no flat pattern", "iLogic")
Else
'tell the user there is a flat pattern
MessageBox.Show("This file does have a flat pattern", "iLogic")
end
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
Misael_Ramalho
Message 3 of 4 (1,112 Views)
04-10-2012 05:27 AM in reply to: Curtis_Waguespack
Hi Curtis_Waguespack
I thank you for your cooperation... but still I'm with problems.
I'm using your code sample for you sent me...
When create a new Sheet Metal file in Assembly environment, through the Create Component command, when click in save two files will saved, the assembly and the Sheet Metal file that was created in Assembly environment, as shown in picture below:
When I click OK appears the error mesage:
iLogic Rule Error in rule: RMDIMENSION, in document: AAA.ipt
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
As shown in picture below:
This error occurs because the Sheet Metal file is being saved in Assembly environment?
You know how to solve?
M_Ramalho
Curtis_Waguespack
Message 4 of 4 (1,092 Views)
04-10-2012 01:27 PM in reply to: Misael_Ramalho
Hi M_Ramalho,
I think your original issue was the lack of a flat pattern definition, but I introduced another issue with my example. In that example I used:
I should have used:
oDoc = ThisDoc.Document
I also noticed that when I copy and pasted the example before I missed the ending IF. Here is a correct example. I apologize for any confusion I caused.
I hope this helps.
Curtis
Else
end if
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
