Inventor General
Member
Message 1 of 7 (1,011 Views)
iLogic Multivalue Parameter
1011 Views, 6 Replies
07-24-2012 03:29 AM
Hi All, do you know how to populate an Inventor Multivalue PARAMETER using a For cycle in iLogic according to a variable index corresponding to a different number of array items?
for example:
i grab some data from a Rule and populate an Arraylist variable. I trace the number of instances using a counter. after the data acquisition I want to populate the Multivalue Parameter with the acquired values.
No problem browsing the Arraylist parameter: MyArraylist.(Index)... but what about the Multivalue parameter?
the MultiValue.SetList("Multivalue Parameter", Value 1, Value 2, ... , Value N) provide a defined number of data and cannot be set dynamically according to an Index.
thank you in advance
Active Contributor
Message 2 of 7 (989 Views)
Re: iLogic Multivalue Parameter
07-24-2012 07:25 AM in reply to: matteo.pallaroni
Out of my breif knowledge I would suggest you can use another Array, populate that and then send it to the paramer.
i.e.
' Your extracted value
Dim MyOriginalArray as New ArrayList
MyOriginalArray = .......
'Declare an arbitrary array
Dim lstSecond as New ArrayList
' filter out as however you would like
For i = 1 to 10
      lstSecond.add(MyOriginalArray.item(i))
Next i
'Populate the paramter
Multivalue.List(YourParameter") = lstSecond
Hope this helps
Member
Message 3 of 7 (975 Views)
07-24-2012 08:27 AM in reply to: matteo.pallaroni
Multivalue.List("MyParameter") = ArrayList was exactly what I was missing. It works perfectly without any cycle for filling in all he values and it depends on how many values are stored into ArraList.
Great, Thank you!
Member
Message 4 of 7 (138 Views)
03-10-2014 11:45 AM in reply to: matteo.pallaroni
Can I add new values immediatelly to Multivalue without creating array ?
Member
Message 5 of 7 (120 Views)
03-11-2014 02:38 AM in reply to: S_Kornilov
yes of course; the default string definition is explicit; you decide which are the values and the position in the list:
MultiValue.SetList("test", 0.5, 0.75, 1.0, 1.25)
test is your numeric or text parameter within Inventor
Member
Message 6 of 7 (105 Views)
03-11-2014 06:53 AM in reply to: matteo.pallaroni
And how I can add fifth parameter 1.5 ?
For example, I want to add new values in cycle
and don't know about their quantity
Member
Message 7 of 7 (94 Views)
03-11-2014 10:49 AM in reply to: matteo.pallaroni
Sorry, quality, of course
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
