Inventor General
New Member
Message 1 of 1 (52 Views)
iLogic Issues with unsupressing iassembly members within master assembly
52 Views, 0 Replies
01-02-2013 04:57 AM
Fairly new to all the ilogic rules and programming. Have got reasonably far....but have hit a brick wall and am desperate for help....before i go crazy..
Basically I created an iassembly with 18 members and placed within a master assembly which has in total 4 iassemblies in with 18 memebers each.
they each have unique part numbers, problem is trying to unsuprress the part numbers, once I have supressed them.
The parts change dependent on the length, the other lengths are supressed, when I come to select the correct length to unsupress the part its comes up with ERROR in rule Component: The Component named "11111:1" was not found.
Example of the rule written that doesnt work to unsupress members, once the lngth has changed..
MultiValue.SetList("LENGTH", "10","15","17.5","20","25","30","33","35","38","40","45","47","48","50","55","60","65")
If  SINK_REQUIRED = "NO" And LENGTH = "10" Then
Component.IsActive("11111:1")= False
Else If  SINK_REQUIRED = "YES" And LENGTH = "10" Then
Component.IsActive("11111:1")= True
Else If  SINK_REQUIRED = "NO" And LENGTH = "15" Then
Component.IsActive("22222:1")= False
Else If  SINK_REQUIRED = "YES" And LHD_LENGTH = "15" Then
Component.IsActive("22222:1")= True
End If
Please help????????? Thanks
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
