Solved by VinodBalasubramanian. Go to Solution.
Solved by iDS!. Go to Solution.
You can try the following technical solution. This would help in fixing your ilogic addin problem,
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
after sp's 1&2 applied ...3 restarts of IV later it seemed to clear up the problem...however mCADForums had a suggestion to delete the file in question with the error message..."user" file ...by which IV just recreated...all is fixed
Thanks for your help!
Glad to hear that everything is working fine. I will set this thread to closed now. This would help others to find this solution.
