Hi All,
I am trying to write a rule for restricting save rights to a .ipt or .iam file. I am just starting out with ilogic and have very basic coding experience.
What I would like is for the rule to read the windows login username and depending on the result (User A) displays a radio message box asking if if the file should be restricted.
If the file is to be restricted, then the rule should allow only User A to save the file. Hopefully that makes sense.
I have posted the code I have so far. I don't know how to get the windows username so have substituted this with username for the moment.
If Username = "User A" Then RestrictAccess = InputRadioBox("Should this file be restricted?", "Yes", "No", RestrictAccess, Title := "Restrict Access") End If If RestrictAccess = True And Username = "User A" Then ThisDoc.Save Else ThisDoc.Document.SaveAs End If
I know my current code doesn't work. I just posted it to give an idea of what I'm looking to achieve.
Oh ok
Do you mean that It wouldn't be posible to get the windows username from ilogic or something else?
If it's not possibile to get the windows username, would it be possible to get the username from the applications options?
thanks for any help.
You can get the WIndows username (I don't have it at my finger tips, but I'm sue you could find a snippet if you searched the Inventor customization forum).
I just don't think iLogic will work very well for controlling file editing permissions. I don't know how much anti-tamper you need but all it would take is a right click suppress or delete on your rule to "unlock" the file. More importantly, I'm not sure how you could capture the save command to keep it from executing. Have you done any experimenting to see if it's possible?
Suppressing the rule won't be an issue as the user we're trying to restrict, doesn't have a lot of experience using inventor, and has never even heard of ilogic.
I haven't experimented with the save command yet. My thoughts on it would be to trigger the rule before save then write a rule to abort the save command and trigger the saveas command instead.
I don't know how possible this would be though.
Have you considered using read only files instead?
You could write an API routine (I don't know if it would work in iLogic) that would mark the file read only or not based on the user name...
Never underestimate the power of ignorance.
Hi gcooper79,
I think mrattray is probably right in thinking that iLogic might not be the best tool for this, but it doesn't hurt to try I suppose. Here are some snippets I had on hand for setting and clearing the read only flags. These snippets do it for the entire folder the file resides in, but you can change it to target only the file as needed.
I hope this helps.
Curtis
'clear the read only flag on all of the files found 'in the same folder as this file 'get the file path Dim strPath As String = ThisDoc.Path & “\” ‘clear read only flag SetAttr(strPath, vbNormal + vbArchive) Dim strFile As String = Dir(strPath) Do Until strFile = "" ‘clear read only flag SetAttr(strPath & "\" & strFile, vbNormal + vbArchive) strFile = Dir() Loop
'set the read only flag on all of the files found
'get the file path
Dim strPath As String = ThisDoc.Path & “\” ‘clear read only flag SetAttr(strPath, vbNormal + vbArchive) Dim strFile As String = Dir(strPath) Do Until strFile = "" ‘set read only flag SetAttr(strPath & "\" & strFile, vbReadOnly + vbArchive) strFile = Dir() Loop
@theo.bot wrote:Maybe it's easier to use a datamangement tool for this like Vault.
Theo
Agreed. If you're trying to prevent users from working on files that other users may be actively working on, then your best bet would be to go on and grab Vault so that you can incorporate a nice check in / check out into your work flow.
If that isn't your goal, perhaps you can explain in a bit (or a lot) more detail, about what you're trying to do, and why.
I agree that vault would solve the issue. However, the company has not yet installed Vault and the department that has the user issue are not too keen on using Vault anyway. I think they have solved the problem by sacking the user anyway 😉
thanks for all your help.
