Hi Nelson,
I believe you could use the Inventor API ReferencedOLEFileDescriptors property of the Document and the delete method of the ReferencedOLEFileDescriptor object to do what you need. If you could provide a small assembly that I could use to test I could create a VBA example. (if you want to keep it private upload the assembly files to the case)
Wayne
Hi Nelson,
I created this blog post with an example that deletes the links in the parts in the assembly you sent me:
Be sure to back up your files before trying it. (It saves the files that have links removed).
Open the assembly and load the RemoveOLELinks.ivb. (load project in Inventor VBA) Run AssemblyCount_updated() to remove the links.
Wayne
