Hi folks,
I have a small problem with iLogic forms picture folder. Is there a way of seting the image by the selected tab ?
I want to update the image by the tab selection.
I have tried "if" or "select case" and neither one worked. as I am saying Stair_Properties = True it only makes the tab active. It doesnt indicate if it is selected, here is the code :
If Stair_Properties = True Then
Image = "Image 01"
End If
If Railing_Properties = True Then
Image = "Image 02"
End If
If Riser_Properties = True Then
Image = "Image 03"
End If
'Select Case Image
'Case Stair_Properties
'Image = "Image 01"
'Case Railing_Properties
'Image = "Image 02"
'Case Riser_Properties
'Image = "Image 03"
'End Select
Thanks ...
