Inventor Forum
iLogic Code. Parameters.
4 REPLIES 4
shmartin89
447 Views, 4 Replies
I have code written containing 2 numerical parameters & 1 text parameter. Once each numerical parameter equals a certain value I would like the text parameter to equal a definition.
I have no problem getting this to work for 1 numerical value but not for 2. The iLogic does not seam to take the second numerical parameter value into account. How do I get iLogic to look at the first value & then also the second before determining the value of the text parameter.
This is my code:
If Parameter("PFC_HEIGHT")=100 AndAlso Parameter ("PFC_WIDTH")=50
Parameter("Name2")="100x50x10"
End If
Tags (2)
4 REPLIES 4
shmartin89
in reply to: shmartin89
Sorry, this is my code. I missed a line.
End If
iProperties.Value("Custom", "Name2") = Name2
mrattray
Try this:
If PFC_HEIGHT=100 And PFC_WIDTH=50 Then
  Name2="100x50x10"
End If
Mike (not Matt) Rattray
shmartin89
in reply to: mrattray
This didnt work. The second If is ignored by iLogic. Luckily the sum of the parameters is unique for each part so that was a way round the problem. It still doesnt solve it though.
mrattray
Do both PFC_HEIGHT and PFC_WIDTH show up blue in the editor?
Are you doing anything else with these (or affecting these) parameters upstream in the rule?
Can you attach the part here for us to look at? I use And & Or statements all the time in iLogic and I've never had this problem.
