Inventor Forum
iLogic 3rd Party object visibility in Drawing enviroment
2 REPLIES 2
asalcedoq
423 Views, 2 Replies
Greetings to all .
Hope you can help me. I have a file with idw extension, on a sheet which show an embedded spreadsheet with relevant information about the product specification. It happens that the same product can make you different specifications (for now only two ) which led me to have two files with the only difference being the aforementioned spreadsheet. With the help of iLogic, I want this to change , creating a multivalued parameter with iLogic code That change the information displayed on the spec sheet . So, I thought the following ideas:
1) Create two embedded spreadsheet ( or how many you need ) and remove all visibility except for the concerned.
2) Create a single spreadsheet with all possible specifications and the drawing sheet showing me only for the current parameter a specific range.
3) Create the table and its variants completely with iLogic code .
Although they are good ideas, and all I would be useful, I just have a little problem ... so far I as I refer to a 3rd Party object in the environment iLogic , so I would appreciate a lot if I give advice and share with me your experience , because it seems very useful and I think it's strange that no one asked this before.
2 REPLIES 2
4donwan4
in reply to: asalcedoq
You might want to post this question here as this is more for the customization area.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Don
asalcedoq
in reply to: 4donwan4
Done.
Thanks Don.
Regards.
ASalcedo
