Inventor Forum
iAssembly Table gone
10 REPLIES 10
Message 1 of 11
nbradbury
429 Views, 10 Replies
I have been creating some iassemblies and I just ran into a problem. I had a factory that had about 400 members. I then added four new options and I know have about 1200 members. After I edited the excel file and closed it the list of members below the table icon in the model panel disapeared (see attached). I can't change the members any more. I tried re-starting Inventor. I tried changing the "List By" keys and member name back and forth. I opend the table to edit and verified the members. I cannot get it to work.
Is there a limit to the number of members you can have? If not does anyone know how I can get this assembly working agian?
Inv 2008 Pro
All service packs available.
Nathan
10 REPLIES 10
Message 2 of 11
nbradbury
in reply to: nbradbury
So I just delted several rows in my iassembly to make sure I was under 1000 members. I have 981 now and the members are back in the modle panel. Is 1000 members the magic number? If so why? I was planning on creating approximately 8,000 members with this file.
Nathan
Message 3 of 11
Nathan,
The max for columns and rows is:
column 256
row 65536
COLUMN 256
ROW 65536
wrote in message news:5935033@discussion.autodesk.com...
Nathan
Message 4 of 11
Nathan,
Well, I sent this before I intended to, but the numbers are correct, 256 and
65536. What version of Excel are you using?
Can you zip up your assembly and send it to me at
richard.willis@autodesk.com?
I'd like to take a look
Rich Willis (Autodesk)
"Rich Willis (Autodesk)" wrote in message
news:5935432@discussion.autodesk.com...
Nathan,
column 256
row 65536
COLUMN 256
ROW 65536
Nathan
Message 5 of 11
karthur1
I had this issue on an iAssembly that I did back in R11. I was told that for performance reasons, when the number of rows exceed 1000, Inventor hides the tree view so it would not need to go through the lengthy updates.
That must still be the limit.
There probably is a way around it by editing the registry if you really need to see the members.
Message 6 of 11
karthur1
Message was edited by: karthur
Message 7 of 11
nbradbury
Do you know longer have any issues with iassemblies being over 1000 members?
How do you generate members if you cannot see them in the tree?
Message 8 of 11
nbradbury
The file zipped is 27 MB. I have Excel 2003, but that should not make any difference.
Message 9 of 11
karthur1
It has been a while since I messed with those that large. I am sure that I still have the issue, but I now try to keep them under 1000 rows.
When you place it in an assembly, can you not chose the table view?
There are ways around it.
Message 10 of 11
johnsonshiue
Hi! If any of the columns is marked as Key column, by default 1000 is the maximum number of rows shown in the browser.
If you need to unblock the limit, you can do one of the followings.
#1, Do not mark any column a key. Or
#2, In a command line, execute regedit.exe.
Go to HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionX.0\System\Preferences\Catalog\
Add a new DWORD, "MaxRowInBrowser" and its decimal value is equal to the maximum number of rows you want to display.
Johnson Shiue
johnson.shiue@autodesk.com
Software Test Engineer
Message 11 of 11
LOONYLEN
in reply to: johnsonshiue
Hello Shiue,
Could you be more specific with the modification?
I have a major problem with a huge iassembly.
My Keys have all disappeared.
Please help, I will check back first thing Monday morning.
Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
