Hi! If any of the columns is marked as Key column, by default 1000 is the maximum number of rows shown in the browser.
If you need to unblock the limit, you can do one of the followings.
#1, Do not mark any column a key. Or
#2, In a command line, execute regedit.exe.
Go to HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionX.0\System\Preferences\Catalog\
Add a new DWORD, "MaxRowInBrowser" and its decimal value is equal to the maximum number of rows you want to display.
Johnson Shiue
johnson.shiue@autodesk.com
Software Test Engineer
