Inventor Forum
i part factory
2 REPLIES 2
Ray_P
528 Views, 2 Replies
i part factory
Hello does any one know of a way to mirror an I-part in the part factory table. I have searched and tried and sure would be nice. When a left hand part is required in a model there is not an easy way to mirror a factory part. I have recently found that if I derive in the parent factory part rather than the child component I can get better results. I set the parent part to desired configuration and update then suppress link in the mirror part. This works well but to create an I-Factory assembly it is not feasible as I cannot use table replace feature in the I-Assembly. Any help would be greatly appreciated. Thanks
2 REPLIES 2
IgorMir
in reply to: Ray_P
Hi Ray,
It's pretty simple. Please see the attached iPart. The file is in IV2010 format.
Best Regards,
Igor.
Web: www.meqc.com.au
Ray_P
in reply to: IgorMir
Thanks this helped I had to resolve some issues with the flat pattern errors but it does work. Thanks to IgorMir
