I had some help from the group to write script to change view reps in a part file skeleton sketch and now I want to do the same in an assembly.
the original code is:
Dim oPrtCompDef As PartComponentDefinition
oPrtCompDef = ThisApplication.ActiveDocument.ComponentDefinition
(With this line setting one view active)
oPrtCompDef.RepresentationsManager.DesignViewRepresentations.Item("FO-Solutions").Activate
(Or the other view active)
oPrtCompDef.RepresentationsManager.DesignViewRepresentations.Item("FR-Solutions").Activate
I rebuilt my skeleton in an assembly file and want to do the same thing in the assembly file but
the deffinition: Dim oPrtCompDef As PartComponentDefinition
is not valid for obvious reasons...
I thought it would be something like "AssemblyComponentDefinition"
But that does not appear to be valid eigther.
I need to find the magical incantation that would replace the "PartComponentDefinition"
So that I can change view reps.
Where last time i was just turning on and off sketchs this time I expect I will be turning on and off not only sketches but assembly components as well.
Thanks in advance...
You should try ComponentDefinition instead of PartComponentDefinition...
