Hy!
Can't I create ex novo obround i-feature (CUT -> see attachment Immagine.jpg) so that I can see the same preview ?
Thank you.
Olá Sato,
Sorry if I did not understand, but the question here is how to create a new iFeature or edit an existing iFeature?
The video only shows you are trying to directly open a iFeature. You can open it, but only to edit the parameters table, for example, to add or remove parameters, properties and other stuffs.
If you want use the iFeature in a part, in order to produce a cut or join material you must:
If the question is not this please tell me
Hy!
Sorry, I want create a new i-feature obround in order to produce a cut material .
Thank you very much!!!
Hi again
To create a new iFeature you must:
(images attached)
