Inventor Forum
i-feature Oberound
6 REPLIES 6
441 Views, 6 Replies
i-feature Oberound
Hy!
Can't I create ex novo obround i-feature (CUT -> see attachment Immagine.jpg) so that I can see the same preview ?
Thank you.
6 REPLIES 6
MariaManuela
Hi
Attach file here.
Asidek Consultant Specialist
www.asidek.es
in reply to: MariaManuela
Hy Maria Manuele. I can't attach ide file, so I've attached a video.
Thank you!
MariaManuela
Olá Sato,
Sorry if I did not understand, but the question here is how to create a new iFeature or edit an existing iFeature?
The video only shows you are trying to directly open a iFeature. You can open it, but only to edit the parameters table, for example, to add or remove parameters, properties and other stuffs.
If you want use the iFeature in a part, in order to produce a cut or join material you must:
  1. Open the *.ipt file
  2. Then in Manage > Insert iFeature
  3. Define the sizes id desired
  4. Finish
If the question is not this please tell me
www.asidek.es
Hy!
Sorry, I want create a new i-feature obround in order to produce a cut material .
Thank you very much!!!
MariaManuela
Hi again
To create a new iFeature you must:
  1. Create a simple IPT file with a Extrusion feature (this Extrusion will be the base of the Cut feature) - image1
  2. Then create the extrusion/cut feature as desired - image 2 and 3 (note if you want that iFeature cut always all the material you must choose Cut All in the Extrude dialog box)
  3. Its preferred to rename the parameters before extracting iFeature - image 4
  4. Extract iFeature - image 5
  5. Save the iFeature in desired location
(images attached)
www.asidek.es
Tags (1)
