Inventor Forum
i-Logic model view
4 REPLIES 4
deltades
486 Views, 4 Replies
i-Logic model view
I need to turn on and off the visibility of sketches in part file. I have views set in the part file that have the visibility of sketch "A" on and sketch "B" off in view A and sketch "A" off, sketch "B" on in view B.
I want to use iLogic to switch between views in a model.
view and capture current state of a view are available in the model tab of the editor but nothing happens when I attempt to capture the state of view "A" ect...
is there anyway of doing this?
Thanks in advance.
4 REPLIES 4
in reply to: deltades
"I want to use iLogic to switch between views in a model."    (your desire seems clearly stated)
A prudent ansewer to this would be:   "double click on the view to switch,  why use iLogic?"
So I am assuming you want to do something else, please clarify what exactly you want to do.
T.S.
mrattray
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("MyViewRep").Activate
Mike (not Matt) Rattray
deltades
The project is for a "configurator" that will be used by several people. I am attempting to ensure that only pertanent information is desplayed to the user given data entry to a form.
mrattray has your solution then.
after you activate the view rep,   then set the sketch visibility as you wish, and activate the next view rep and do the same.
T.S.
