Hi!
Easy one... With Inventor 2014, how do we set an hydrostatic load in a static stress analysis? I see how I can set a constant pressure on an area, but I don't see how I can set a linearly decreasing pressure.
Thank you very much!
You will have to do a bit of fudging and Split the faces into contours.
Should be able to get "close enough" results.
This topic has been covered here before - a search might turn up previous discussions.
As JD mentions, a discussion of a workaround is here: FEA question: Hydrostatic Pressure
Hope it helps...
Regards, -Hugh
