inventor 2013- I have to build a tool which I use all english but the base part the tool is making is in a iges file that is when I load is metric. Is there a way to convert this or do i have to redraw this?
Solved by JDMather. Go to Solution.
There is really no reason to convert - Inventor is units aware, so it is what it is. (I would simply leave it in it's original units.) (I would certainly not redraw something that is already done.)
If you really really really want to change the units for some reason go to Tools>Document Settings>Units in the ipt file.
You should not need to scale anything unless for some reason the Units were not set in the IGES file.
Zip and Attach your original IGES file here if you can't figure it out.
when I open a new assembly drawing and place the first componet which for example is a 1 x25 x 25 inch plate then place the file file from the customer (open as iges and saved as inventer) it comes in way large like it is 300 inches by 300 inches but is 300 mm.
thanks
It doesn't sound like the IGES file was saved with units.
Click on the file but before Open select Options.
