Inventor Forum
how to show millemeters squared in a note
4 REPLIES 4
1093 Views, 4 Replies
Is there an easy way to add the superscript "2" to a note for millemeters squared in Inventor 2010?  example:  mm2 or FT^2
4 REPLIES 4
karthur1
You can find more by searching the Help.  Search on "Superscript".  The first on the acomes up is "Stack text in drawings"...... try that one.
Kirk
mcgyvr
in reply to: karthur1
ALT + 0178 for squared
ALT + 0179 for cubed
Lets see if it works here
5mm² and 5mm³
yep
This solution worked for squared "3²" and cubed "3³" but does not solve if someone needs to add superscript or subscript to a text line.
I tried Stack text but that didn't work.
I tried "CTRL"+"SHIFT"+"=" but that only works in the format text window.  The formating goes away after I click ok to close the format text window.
karthur1
Not sure what you mean by a "text line".  Everything I tried worked, so I must me missing something.
Post a screen shot of where you are trying to add the superscript.
