Inventor General
*Frodason, Finnur P.
Message 1 of 4 (57 Views)
how to show cut / uncut material
57 Views, 3 Replies
11-17-2002 11:31 PM
How can I show uncut and cut material using the same ipt and/or iam file.
A customer is designing a wheel with some knives. These knives are first
laser cut. Then the wheel is assembled and the assembly is turned to final
tolerances.
Is it possible to make different views in idw. One view for cut material and
one view for finished part?
Regards
Finnur P.
Distinguished Contributor
rllthomas
Message 2 of 4 (57 Views)
Re: how to show cut / uncut material
11-17-2002 11:37 PM in reply to: *Frodason, Finnur P.
I haven't tried anything like this yet but it sounds like the perfect opportunity to try out the assembly features. Create an assembly, drop your unground knife in it. Create the grinding with assembly features. Show both the part and the assembly in the drawing. - Rich Thomas
*Dotson, Sean
Message 3 of 4 (57 Views)
11-18-2002 12:14 AM in reply to: *Frodason, Finnur P.
In addition to Rich's suggestion you might also look at derived parts. This
is the process I use to show pre/post machining operations. Make part of
the unfinished knife then derive the part and add the features to show it
finished. If you change the basic base part (unfinished) the derived part
(finished knife) will update to follow the changes.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Finnur P. Frodason" wrote in message
news:B54323C1CD155BD60F6E5E8A73CD27C8@in.WebX.maYIadrTaRb...
> tolerances.
and
> Regards
> Finnur P.
Message 4 of 4 (57 Views)
Re:
11-18-2002 04:21 PM in reply to: *Frodason, Finnur P.
I'll give it a try
Finnur P.
"Sean Dotson" wrote in message
news:62E9A3896AFFC3E52BDC780E12FFCCFE@in.WebX.maYIadrTaRb...
This
> Sean Dotson, PE
file.
final
> > tolerances.
> and
> > Regards
> > Finnur P.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
