I am using Inventor 2010.
I have a sheet metal box where I created the 4 outer flanges in the same flange feature because they were all going to be the same length. Now because of a design change, I need to delete one of those edge flanges leaving just 3.
These flanges have holes in them. What is the best way to do this without deleting the entire feature and having to recreate the 3 flanges and all the holes in the part again. I can see where you can add an edge but not to delete one.
Solved by Mike_Maenpaa. Go to Solution.
Edit Feature, hold the Ctrl key on keyboard and pck flange to be removed, click Ok.
Mike
