I have my autocad drawings setup that in the corner of all autocad drawings the time and date changes everytime you open drawings in autocad. i want to do the samething for my inventor drawings. Is there a way to do this in inventor. Thanks
Hi ravencontrols,
You can use ilogic to do this. Here are a couple of links to look at. There is an example file in the first link:
http://forums.autodesk.com/t5/Autodesk-Inventor/time-stamp-MIA/m-p/3104774/highlight/true#M408928
I hope this helps.
Curtis
how do i get this ilogic in inventor cause all i want is date and time to show up everytime i open up a drawing in inventor
Hi ravencontrols,
See this link for the basics of creating an iLogic rule that triggers on an event (such as a Save or Open file event):
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
Paul Munford covers more details on this here, including creating an external rule (one that is not stored in a particular file):
http://www.augi.com/library/playing-by-the-ilogic-rules
And here is another reference in case it helps:
http://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
I hope this helps.
Curtis
